wa8yxm
Jun 08, 2014Explorer III
Laptop charging depends on the laptop. Mine need a DC/DC converter to charge off 12 volts. this is basically an inverter and power supply in one box.. So I use the Prosine.. Plus there are some other reasons I need to keep one of my laptops off the 12 volt side of life (Isolation issues).
As I said before with slight modification:
(The mod part 1): IF noise is not an issue (If inverter mounted outside for example) Use the one that draws the least current both on standby and in operation.
(mod part 2 and thanks to the person who pointed it out) IF noise IS an issue, use the one that makes less.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
