Gjac
May 02, 2019Explorer III
Are you sure you can't get to the coil without pulling the genset out? I replaced my coil several years ago for less than $100. The hardest part was removing the shroud and some of the other sht metal surrounds. Once removed the coil replacement was easy. It was a half day job including removal of the mouse nest under the shroud on top of the engine, it is a wonder that it did not catch on fire.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
