Sooner_Schooner's avatar
Jan 31, 2018
3M/Diamond Shield Removal
Is there any recommendations or updates on the best adhesive removal product when removing the clear protective film from the front of your motorcoach? I just got my plastic razor blades to start the project , but looking for recommendations for the glue. Thank you.
  • Ivylog's avatar
    Ivylog
    Explorer III
    Heat gun and plastic razor blades for the film. And for the glue..."Citrus Squeeze" of "Orange Squeeze" by CA Sents air freshener. Don't knock it until you try it. Amazing how many things it will remove and you smell good afterwards.
  • 2x On the hair dryer. Get the surface nice and hot and peel a corner away, then point the hot air from the dryer at the back sticky side of the sticker and gently pull it off as you feel the glue release. Finish up with one of the glue removal products from 3M as mentioned or "Goo-Be Gone". Try a little of the removal product on a hidden spot to make sure it doesn't mess up the paint.
  • Go online and check out 3 M products, they have good products may have something that will work, or you could try a hair dryer
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
