mabynack
Nov 26, 2014Explorer II
It can be a loose bulb or corrosion on the connections. The flasher works based on current draw on the circuit. If the current is low, the flasher will flash slowly or not at all. If there is too much current draw across the flasher, it will flash quickly.
