wa8yxm
Nov 01, 2016Explorer III
No, 40 amps does not seem correct less it's one very small Microwave. 100 amps is more what I'd expect a Microwave to draw.
how to estimate battery draw for 120 volt appliances
Watts = Volts times Amps times Power factor
Volt-Amps (if listed) = Volts times Amps
For a Microwave the power factor can approach ONE so we will use that
Assume a battery voltage at the inverter of 10 (this is not correct but there are several things that need to be factored in like conversion efficiency and Inverter "overhead" and such and using 10 volts is an easy way to factor them in at currents less than 100 amps it's fairly close)
Watts/10
So your Microwave must be about a 400 Watt model
Watts/10
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
