Just_Jeff
Jun 05, 2013Explorer
You want your 12v cables to be as short as possible...so put your inverter right next to the batteries (but not in the same compartment because of gasses).
Then make your 120v extension cord do the long run from the inverter to the TV.
The reason is you'll get a lot more voltage drop with low-voltage (12v) cables than with 120v cables. It's a lot more efficient use of power this way.
Having RV issues? Connect with others who have been in your shoes.24,383 PostsLatest Activity: Apr 24, 2026
