KD4UPL
Jun 05, 2013Explorer II
To answer the original question, yes you definitely need a fuse in the battery connection. NEVER connect a wire to the battery without a fuse in the positive lead. If there is ever a short in the wire a fire will likely result.
A 400 watt inverter will pull nearly 40 amps at full load. This will require #8 wire at minimum. Larger would be even better. A 50 amp fuse should be enough. If you run larger wire you can increase the fuse size appropriately.
Having RV issues? Connect with others who have been in your shoes.24,383 PostsLatest Activity: Apr 24, 2026
