Salvo wrote:
Well, not quite. If we got a 150A load and 4 batteries each with 15 mohm resistance, the 12V batteries will dissipate 84W, while the 24V batteries will dissipate 21W. There's a factor 4 difference in power dissipation.
DryCamper11 wrote:
Yes. Same batteries, same stored energy, and the MW runs the same length of time (approximately).
He was commenting on the length of time the microwave runs, not on the change in power loss due to cabling and battery internal resistance. That's roughly the same length of time.
I went through the calculations on power dissipated in the cabling, and discussed why that's reduced to a 1/4, and yes, there's also less loss in the batteries, but the power dissipated in cabling and batteries isn't really going to have a huge effect on the length of time that a microwave runs. 150A at 12V (or 75A at 24V) is 1800W.
Even if we use your numbers, the difference is that the energy used to run a MW for 15 minutes with a 24V setup would run the MW 33 seconds less with a 12V setup. That's why I said the run time would be "(approximately)" the same. I don't see that as being a major reason to go with 24 volts over 12 volts.
The efficiency of the inverter is probably more important than the power loss differential due to the current change.
