BFL13
Nov 21, 2016Explorer II
I do agree the PD with its Charge Wizard is a good compromise for its features to be the RV's converter for many RVers.
But if you want your rated amps, you have to notice what people are saying. 55-57a or 53a from a 60 amper???? Another member gets 66 with his PD 70 amper. Pathetic! :(
In the past when this came up, the usual suggestion (by smk, eg) was that if you insist on buying a PD, then get the next size up so you will get the amps you are actually looking for.
So in this case getting the 60 instead of the 45 is the correct choice so you will hope to get 55.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
