D_E_Bishop's avatar
D_E_Bishop
454 Chevy has low power and high gas usage/some help
My Bounder's engine started running bad a few years ago and at night you could see the leakage from the plug wires. Decided to have full tune up done. Many hundreds later I got it back and it still ran bad. Long story short, at least three years 4 or 5 shops and still running bad. Hesitates when you first step on accelerator, no power, and when you floor it at the time the rear barrels open, even less power. Well last week we were E/B from Fort Smith AR and it suddenly started running like it did several years ago. Ran great up to Russelville and then is went back to same 'O', same 'O' cra--.
I decided that when we got home I would take it to a high performance shop near the house. Well a couple of days later we're in Paducah KY and a bunch of us guys were talking about engine performance and my problem came. Consensus was it didn't make sense. Today I was thinking about the biggest problems I have are with the vacuum system. I also thought back some time ago when the kids were young and we were going over Loveland Pass in our Type 2 VW Bus. No power and high consumption. We also talked about Model A Fords and manual spark advance.
Well I sent the DW off to look at quilts and I pulled the cover off the doghouse. Ultimately what I found was a badly worn and flimsy vacuum hose on the vacuum advance of the distributor that would collapse and seal off and hold the advance at full advance.
All the symptom fell into place considering the vacuum problem.
I need to get a new length of hose and install it but just trimming off the end has made the engine run much better.
There has to be at least 100 feet of various size hoses and I would love to replace them all but I don't think I could and I just don't think I can afford to have it done, so at least I know what to look at when the engine runs crudy.
Improvement in mileage and power. My first tank of gas since Paducah showed a 20% + increase in mileage and a 75% improvement in power. There are still a couple of problems but the improvement is amazing. I was getting 3.5 to 5 MPG and now 6.3 MPG. I will buy 25 feet or so of hose and replace all I can as per darsben's suggestion. I am still going to have the distributer pulled and run on a test stand and have Blair's do a final tune up. With the engine testing as a Gross Polluter and mechanics tweaking it so it woud pas smog last year I am sure it way off.
Thanks for all the suggestions.
Having RV issues? Connect with others who have been in your shoes.24,259 PostsLatest Activity: May 30, 2025
