pianotuna wrote:
Yes and I think 95% conversion of rated watts getting to the air conditioner is a bit optimistic.
I agree that no one who is attempting to run an air conditioner would worry about having too many watts of panels.
Hence my WAG to increase panel rating by 50%... not just to have extra.- pianotunaNomad IIIHi SMK,
This page suggests to me that it is 1100 watts--but I see I did not scroll far enough to the stage left--so you are right it is 560 watts.
I'll correct my errors.
solar electricity cost - http://www.geinnovations.net/Specifications.html
Check the power input specification.
12,000 BTU 560 watts
15,000 BTU 770 watts
18,000 BTU 1368 watts
The OP link gives the 95% panel to load efficiency assumption.
Math seems to be a very simplistic spreadsheet. No calculus here. - MEXICOWANDERERExplorerThat's amazing.
My little LG 5,000 BTU window AC, sucks 600 amp hours out of my 24 volt bank every 24 hours. Wonder what I'm doing wrong? Yes, the compressor is doing 100% duty cycle. - pianotunaNomad IIIHi smk,
Correction of my misreading of the web page.
I agree that no one who is attempting to run an air conditioner would worry about having too many watts of panels. - 12,000 BTU says 560 watt load. So the calc is just a simplistic 589w(solar) x 95% = 560w(load)
I would plan on 50% more panel than the chart shows. Need lots of battery to get through a hot night. Going to lose significant efficiency in the battery to go 24 hours even if only 18 hours run time is needed. - JiminDenverExplorer III wonder how they are working it out. 4 hours of sun on 589w of panel isn't going to offset 4 hours of a 1100w load even with off peak sun. The 12000 BTU unit must pull less than that, I have seen 9000 BTU mini splits that only pulled 600w and were not considered all that efficient.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
