HadEnough
Oct 06, 2018Explorer
wolfe10 wrote:
If you are safe working around 120 VAC, start at the ATS and see if you are getting power from the generator there (yes, assuming you have an ATS vs manual "plug to play").
If not, check at the generator to house wiring box.
If not, check at the generator breakers.
Ok,. Thanks.
I should have posted what I have done.
I checked the breaker in the generator and the DC fuse In the same spot.
I opened up the ATS and tested for incoming power while the generator was running and I wasn't connected to shore power. Nothing.
I'll have to locate the junction box wiring generator to house circuit. It appears to be inside the generator compartment on my Arctic Fox truck camper.
Having RV issues? Connect with others who have been in your shoes.24,391 PostsLatest Activity: Jun 07, 2026
