bounder39zman
Oct 24, 2018Explorer II
please........ post your model and spec #. Those who may hsve info to help you may be better able to help you. If the Genny continues to run after start up, then it is making a.c. power. The control board will shut it off after start-up if not making power. Problem is likely at connection box or at c/b connections, as O.P. have suggested.
Having RV issues? Connect with others who have been in your shoes.24,391 PostsLatest Activity: Jun 07, 2026
