HadEnough
Oct 28, 2018Explorer
bounder39zman wrote:
please........ post your model and spec #. Those who may hsve info to help you may be better able to help you. If the Genny continues to run after start up, then it is making a.c. power. The control board will shut it off after start-up if not making power. Problem is likely at connection box or at c/b connections, as O.P. have suggested.
Ok. I'll get that model number ASAP.
It's an Onan Microlite 2500 lp
There is a hot, neutral and ground that comes out of the side of the generator itself. These are connected to something inside the generator and connected to the connection box on the RV.
I disconnected the generator from the RV at the connection box to see what was going on. No power out of the generator. The hot, neutral and ground coming out of the side of the generator have no voltage on them relative to each other.
Which is why I was asking how people run these propane generators on the bench. Next step is I have to remove the generator to be able to get inside it. It's inaccessible the way it's installed in the RV.
When I remove it, it has no propane source. How do people usually supply the propane to run them on the bench?
Having RV issues? Connect with others who have been in your shoes.24,391 PostsLatest Activity: Jun 07, 2026
