Michael1107
Aug 26, 2016Explorer
joshuajim wrote:
The 5-2-1 is a 3 wire start assist. The main difference between a 3 wire and a 2 wire like a Supco is that the 2 wire uses what I will basically call a heat switch to remove the cap from the start circuit. It switches off when it reaches a certain temperature, usually in a couple of tenths of a second. A three wire senses when the compressor reaches about 75 percent of run speed and then cuts out.
When running an RV A/C on a smaller generator, the rpm and voltage dip at startup but the start cap cuts out before the generator can get the compressor up to speed. This usually is the cause of a no start. A three wire stays in circuit until the compressor reaches 75 percent of full speed and usually will start the A/C much better than a 2 wire.
Some people will say that it is bad for the windings for the cap to stay in circuit for a longer time, but there are trade off on everything and with the limited wattage of a small generator that has not likely.
My Yamaha 2400 starts my 13.5 every time at up to 7000 MSL using a 5-2-1 three wire start assist.
What model A/C unit do you have? I've got an Air Command AC1501 (15K BTU), and was talking to the 5-2-1 (CPS Products) tech support line today. I got in touch with a very nice gentleman who retired from 5-2-1, and is a part time consultant for them now. He was a designer for the company for many years. He was telling me that the 5-2-1 kit was meant for 240V systems, not 120. His concern was that the potential relay would not open up because the pick up voltage was too low.
When I told him that there were numerous examples of folks using them on RV applications, he was surprised, and more than a little intrigued. I'm hesitant to install it unless I could find someone who had been using it on a unit very similar to mine.
The compressor specs on my Air Command are 15A running, and 63A locked rotor. Is that anywhere near the specs on your unit, and have you had any trouble since you installed it?
Thanks....
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
