howardwheeler's avatar
Jul 03, 2018
5.5 LP Onan has started to backfire and quit
I have an Onan Marquis Gold 5.5HGJAB-1119C that is a vapor LP generator. It is 14 years old and has has been flawless in performance until now. All maintenance is done. But while it has now begun to run okay on no load (though I sometimes detect some occasional miss that’s hardly noticeable), as soon as you apply the load, say of one AC, it begins to falter, then begins to back fire loudly inside the enclosure. I have read the service manual but really don’t have a bead on what’s going on. I wonder if a less than adequate LP supply could cause this. The reason I ask is I’ve had some oil looking stuff in the lines coming from my regulator. Actually the lines going to the regulator from the tanks. I discovered this when I changed regulators a while back. I have a high capacity regulator. Any ideas? Is there any way a low supply of gas can cause backfiring? It does okay when the demand isn’t there, but when it needs more power it starts coughing pretty bad. That’s why I’m wondering if it has gas coming to it but not the volume it needs for a load.
Having RV issues? Connect with others who have been in your shoes.24,349 PostsLatest Activity: Jan 12, 2026
