jjrbus
Feb 15, 2022Explorer
Onan starts and dies
Onan 2800 Microlite.    2.8KVFA11574J,  F010254711.
New to me 2002 Roadtrek with generator of unknown history. Very low hours with what appears to be newer carb and manifold and choke element/spring??
Removed genset, large nest inside, no sign of wires being eaten. Choke element housing broken, repaired. Choke spring out of place and put in place. Wiring 12 and 120 volt disconnected. 120V circuit breaker in off position. Push start button and genset starts quickly, dies in about 2 or 3 seconds. I have tried holding the start button in but the genset dies anyway. Fuel pump appears to be working well. At the moment I have what I am fairly sure is the oil pressure sensor disconnected.
If I spray starter fluid in carb as as genset is dying it runs well for a couple more seconds. However I am afraid to continue spraying fluid.
I have both the service manual and the parts manual. Not sure how to proceed??
