Sam_Spade
Oct 09, 2019Explorer
Several things can happen.
IF....you have the adapter at or near to the supply pole, nothing bad should happen to the RV equipment.
BUT.....
The adapter might overheat.
The 30 amp receptacle might overheat.
The 30 amp breaker at the supply outlet might trip.
It is really NOT good to exceed a 25 amp draw on a 30 amp service because you don't know how good the feed really is.
BUT.....
