swphotobug
Oct 09, 2019Explorer
You don't say what coach you have. Ours is a 50a that runs fine on 30a. We have a system that sheds loads as other components need electricity. An example is the A/C's. Only one will run at a time when shedding. Our coach is a 2015, if yours is newish check to make sure you don't have load shedding. Other than that you will quickly learn what combination trips the breaker. We have all our electic items labeled with how much each takes. We bought a Kill-A-Watt and measured everything.
