hypoxia
Oct 10, 2019Explorer
Sam Spade wrote:
The adapter might overheat.
The 30 amp receptacle might overheat.
It is really NOT good to exceed a 25 amp draw on a 30 amp service because you don't know how good the feed really is.
Excellent advice. Grab the 30 amp adapter after using high amperage for a while. It will almost certainly be hot to the touch. That is going to start melting the adapter as well as overheating the receptacle. Campground electrical get a lot of use and abuse, the connections are usually well worn and not making the best connection. Poor connections = heat. Their circuit breakers are also well worn.
I carry spare 30 and 50 amp plugs for that very reason. We were parked on a farm plugged into a grain elevator this summer. DW called and said we lost power. Turns out she tripped the 90 amp breaker on the grain elevator! Lets see; 3 A/C units, AquaHot 4000 watts, microwave & electric skillet etc. all at the same time!
We had an impromptu class on electrical consumption....:S
