I am changing a 30 amp outlet at my home to a 50 amp for shore power to my MH. Is the 50 amp pig tail hooked to 120 or 240. I know the 30 amp was 120. thanks, Cork
A shortcut money saver is just run another #8 and put in a new double pole 30a breaker and wire in the 50a plug. While you can't run run every single item, a hair dryer and make coffee at the same time, you can easily run both ACs and your fridge.
