I am changing a 30 amp outlet at my home to a 50 amp for shore power to my MH. Is the 50 amp pig tail hooked to 120 or 240. I know the 30 amp was 120. thanks, Cork
If the wires are in conduit Big Katuna has the way I would do it.
If it is Romex.. Well, Depends on the length of the run.
Another alternative is to live with only 30 amps at home and use a dogbone adapter...
If you are USING the MH as a Guest room, in the heat of summer, that will not work as you will need both A/C's but if its only for storage and set up/take down,,, Should be OK.
