ScottG
Aug 28, 2013Nomad
Edward 75 wrote:
I am not real clear as to what you are saying, but if you are saying your hot tube is going away and you want to hook you 5th wheel to the 220 dont dont ever hook 220 to an rv. They are wired for 110 volts only. Hope this helps but donot hook 220 volts to 5th wheel.
Not entirely correct. If the OP has a 50 amp RV then it does indeed hook up to 220V and the spa power supply will be fine if it's 4 wire.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
