westend
Nov 15, 2016Explorer
mbrower wrote:The NEC requires a separate ground rod with subpanel if the panel is a certain distance and if the wires are not inside a metallic conduit. I've lost my book so can't give the sections but I did install a subpanel and remember reading about the different requirements. The rod is sometimes required and sometimes, not.wolfe10 wrote:
Separate ground rod at a sub-panel is a new one on me.
Would appreciate a link to code calling for this.
The ground rods are for a sub panels in a detached structure. If the sub panel is near the main panel, you can use the homes ground.
A Google search will provide endless reading on this.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
