trent8666's avatar
trent8666
50 Amp Outlet Installation Question
Good Evening!
My name is Trent, I own a 2015 Keystone Hideout and need technical advice on installing a 50amp outlet.
I have read many posts on my issue but cannot seem to figure it out for the life of me!
At the area where I park my RV, I have a main panel, and inside the panel, the ground and neutral are connected to the same bar. I will be installing a 50amp RV outlet at the other side of the property, but I cannot figure out my neutral/grounding situation.
I have narrowed this issue down to two possible scenarios...
1. Only run 3 wires from the main panel (120v/120v/neutral) and install a grounding rod at the outlet for the ground.
or
2. Run all 4 wires from the main panel (120v/120v/neutral/ground)...but would I connect the ground and neutral to the same bar at the main service panel?
Any input in greatly appreciated! Thank You!
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
