Cougarnewbie wrote:
Ok. I've read what I can find on installing a 50amp in use outlet on my outside garage wall to plug the RV into when in the driveway. It will be about 25 ft. from the 100 amp service panel. My thinking is add a 50 amp breaker, plastic conduit to the front garage wall. 4 wires, 2 black, 1 white, 1 green. The cheapest exterior box does not include breaker which makes me wonder about GFCI? My primary question is what guage wire? Is 1 inch conduit large enough? I am kind of anal about being within code.
As always, Thanks folks
AL
I believe a 1" conduit will be large enough but important information is that you will need 3-6 GA wires (Red, Black, White) and an 8 GA green wire (ground). If that all fits comfortably inside a 1" conduit then you are good to go.
