I am getting ready to purchase a new fifth wheel after the first of the year and my question is this: Should I have a 50 amp outlet installed in my garage or do they sell an adaptor that will go from...
Will need the two adapters A 50a to 30a (plug your power cord into it) and then a 30A to 15A adapter (plug 30A adapter into it and then plug into house outlet)
50A to 30A
30A to 15A
Don't get one of this 30A to 15A...they are junk
And if you are going to run the fridge........make sure RV is level. Off level operation will cause damage....gravity flow will be restricted and cause improper fluid of cooling medium which will cause clogging....this damage is accumulative
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
