myredracer
Jun 17, 2018Explorer II
How are you going to terminate #4 onto the 50 amp recept. terminals? You probably need to splice #4 to a smaller gauge at the recept. to make it work. If so, the splices will be physically large and require a large junction box adjacent to the 50 amp recept. Same at your panel. I think you'll need split lugs to do this. Before you use the #4 you might want to price out the lugs and junction boxes vs buying some new wire.
Absolutely no reason not to use the #4 wire, except as above and also as noted by another poster above, the insulation jacket on the wire must be code approved for the location and application.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 08, 2026
