wa8yxm
Apr 03, 2020Explorer III
Use a 50 amp outlet.
First do not forget to disable the converter when using the inverter in this manner.
now.. the 50 amp socket has 4 wires Ground (The roundish one) Neutral (Opposite the ground) and L-1 and L-2 To feed the 120 volt 3000 watt inverter to the 50 amp receptical BRIDGE l-1 and l-2 (That is run a jumper wire between them) That easy.
I have two 50 to 30 adapters
One is molded (Dogbone) the other is a 30 amp shore cord. I had to replace the 50 amp Marinc outlet. Yup. Jumper from L-1 to L-2
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
