theoldwizard1
Apr 03, 2020Explorer II
avarusbrightfyre wrote:
My uneducated intuition says maybe another wire spanning from one terminal post to the other, but I'm not sure how safe it is to have current hopping from one side of the outlet to the other.
Safe if done neatly/correctly !
This sounds kind of silly, but you could just buy the adapter, cut of the 30A inlet and splice the necessary length of the correct wire on to it. Again, safe if done neatly/correctly. Do NOT use crimp connectors or other low voltage splices ! Use something like an Ideal Splice Block.
Hint, when hooking the cord to he inverter outlet or before inserting the wires into the splice block, use a soldering iron to "tin" the ends of the bare copper stranded wire.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
