Housted
Apr 04, 2020Explorer III
2oldman wrote:Housted wrote:How often? A 3kw inverter should easily run your air if your batteries can do it.
I have that one and have been using for 2 years.,,powers everything in the coach exept A/C.
If I had the expensive hard start system the 3000 watt inverter would run it. But even with my LI batteries it would not run it for long! I have a built in Onan for use when I need A/C. I have 1050 watts of solar so the generator is vey seldom needed to charge the batts. We boondocked for 10 days in Jan in AZ and only had to run the gen on a rainy day.:)
Houston
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
