BFL13
Apr 04, 2020Explorer II
To exploit 3000w vs 2000w, you would pull 300 amps discharge from the battery bank vs 200 amps. How long you would do that depends on the size of the bank.
Using Lithium batts for this is the same. An amp is an amp and an AH is still an AH. ISTR they have limited discharge rates even if higher. 100 amps per 100AH ? So you will still need say three or four 100 AH batts AFAIK. Big bucks!
So IMO you could do just as well with a simple 2000w inverter, hard wired or not, and save a bundle getting AGMs instead of Li.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
