Naio
Apr 06, 2020Explorer II
Thank you for the link!
Would someone be willing to explain this to me, from the top review? What kind of shut off switch or breaker would I need?
My only complaint and reason for one star off is that the Inverter appears to be the floating neutral type and has 1/2 the voltage on the "Hot" leg and the other on the Neutral. This is not a problem for operation, but a concern if wired into a panel with single pole breakers and the user think they have completely isolated power as would be the case with a bonded neutral in a typical home. It is a subtle but important thing to know depending on the intended use and connection methods. Just be aware of this. I have come to understand this is very common with inverters to prevent ground loops and other issues than can occur with bonded neutrals.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
