Naio
Apr 06, 2020Explorer II
...and is that the reason that this other reviewer experienced a power draw with the inverter switched off?
I have found that I was having a power drain when the converter is shut off. I found the converter takes power when it is switched off. I seem to have about a .68 amp constant draw from the converter, I plan to remedy this using a circuit breaker with a throw switch. When I switch the converter on with no load it uses a approximately 2.65 amps.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
