avarusbrightfyr
Apr 06, 2020Explorer
pianotuna wrote:
avarusbrightfyre,
Magnum does not recommend running a roof air conditioner from their 3000 watt inverter/chargers.
Going to 4000 watts means moving to a 24 or better yet a 48 volt battery bank. Then use a DC to dc converter to power the (low) 12 volt loads, or just use the OEM converter.
Wouldn't increasing to 24 or 48 volts require more batteries to reach the same capacity? I believe I would need twice number the batteries at 24 volts to get the same number of amp hours as a 12 volt setup. I plan on mounting the inverter right next to the batteries and using big fat cables to minimize heat.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
