avarusbrightfyr
Apr 06, 2020Explorer
pianotuna wrote:
If the inverter only has to go from 48 volts up to 120 volts it works a LOT less harder. If I were starting over, I would not use a 12 volt inverter.
That makes sense. However, to get a 48 volt system would require four batteries, and I'm trying to go the LifePo4 route to save on space and weight since you can use at least 90% of the capacity. That's a lot of money up front that I don't have.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
