2oldman
Apr 07, 2020Explorer II
avarusbrightfyre wrote:24v only requires two. 36 isn't very common.
However, to get a 48 volt system would require four batteries...
As explained, you're after watts, which is volts x amps. Whichever combination doesn't matter. And yes, inverters don't have to work so hard when the input voltage is higher.
Solar panels can also be connected in series, which is an easier way to do it and doesn't require fat wire and combiner boxes.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
