pianotuna
Apr 07, 2020Nomad III
MrWizard wrote:
PT
How do you draw over 2400 Watts with MW, is it plugged into a 20 amp 120v outlet
It draws about 1570 watts running (measured by a kill-a-watt meter)--but overhead and voltage drop cause the amps to be 210 (measured by the "head" of the remote). I've been told by Magnum that is some what of an approximate figure.
I've not measured the microwave for a while--and the turntable motor is burned out. It may be that it now draws less.
I go a couple of places where I can only draw about 1000 watts, so I use the hybrid feature of the inverter to do load support.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
