BFL13
Apr 07, 2020Explorer II
A "900w" MW will want more like 1200w input--check its label.
Inverter to 12v divide by 10 for the amps draw. So that 900w MW will pull about 120a via inverter.
24v means buying a 24v inverter and then you are stuck with that. IMO stay with 12v unless you have a special reason to go 48.
Your problem seems to be that you need 440 AH of bank like the rest of us who do a lot of 12v stuff and you don't want to carry that much weight. Too bad so sad, you have to make choices. We carry 440AH ok, but we also don't carry whatever else.
