avarusbrightfyr's avatar
Apr 03, 2020
50 Amp Receptacle to Inverter
Hello all!
Ok, so backstory is I'm doing research on installing a 3000w inverter in my travel trailer, and rather than go through a super complicated and expensive direct to panel wire install, I'm planning using the jury rigged solution of wiring a receptacle to the high output terminals on the inverter and plugging my standard shore power cable into that to power the AC appliances on battery.
The obvious (at least to me) solution is to use a 30 amp receptacle since it only has three wires and that's what the inverters typically come with. Then use a standard 30-50 amp adapter to get my shore power cable plugged in.
Being the efficiency minded person that I am, though, I think it would be nice to avoid using an adapter at all, if possible. I'd like to use a 50 amp receptacle and wire both hot sides together with some sort of bridge, sort of like how they do with the 50-30 amp dog bones. That way I still have just 3 wires coming out of the outlet box but get both legs of the 50 amp cable powered, and I can just plug my 50 amp surge protector straight into the outlet without anything else in the way. My uneducated intuition says maybe another wire spanning from one terminal post to the other, but I'm not sure how safe it is to have current hopping from one side of the outlet to the other.
Any suggestions?
    I'm no 50a expert, but I'll try some of this.
    A direct-to-panel install is a piece of cake, at least it was on my 30a coach. I just found where the shore cable connected to the panel's input cable, broke that, ran it to inverter 120v in, and 120v out to panel. Easy.
    You said "high output terminals." A 3000 watt inverter should have a hard-wire option.. is that what you mean?
Having RV issues? Connect with others who have been in your shoes.24,209 PostsLatest Activity: Feb 27, 2025
