MEXICOWANDERER
Jun 26, 2017Explorer
General Advice
Make absolutely certain that when you push the adapter into the house receptacle (monikered "plug-in") it fits -tight-. This would be one place I would use a replacement receptacle from Home Depot. Ask the salesman to show you a "Nylon" 15-amp receptacle. All nylon receptacles are spec commercial grade and they can ensure higher levels of power flowing through them. Contractor-grade garbage should be outlawed IMHO.
A nylon receptacle has holes on the rear to insert a stripped wire. Then a screw on the side can get the snot tightened out of it. This receptacles are infinitely easier to install than wrapping a 12 gauge wire around a screw.
When a contractor grade receptacle catches fire and burns up an expensive adapter the nylon receptacle will grin and keep trucking. This comes from experience not from reading a magazine ad :)
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
