grizz272ExplorerFeb 07, 201850 amp RV plugI would like to put a 50 amp rv plug on the garage. I would like to see a wiring diagram for that. Any one have one?
BB_TXNomadFeb 07, 2018Everything you need to know. enblethenNomadFeb 07, 2018A fifty amp RV receptacle is the same as a four wire range receptacleSTBRetiredExplorerFeb 07, 2018Make sure to use a weatherproof enclosure if you put the outlet outside.EDIT: You can buy the same pedestal that you see at campgrounds for about $150. That includes the 50A, 30A and 20A outlets with the individual disconnect breakers.time2rollNomadFeb 07, 2018LwiddisExplorer IIFeb 07, 2018Without a licensed electrician RV experienced? I wouldn’t like that.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,190 PostsLatest Activity: Jan 22, 2025
