alaska_av8r's avatar
alaska_av8r
50 amp service, Inverter vs Converter
Sorry I originally had this posted in travel trailer section then moved it here.
I am in the process of gutting out an 18 foot travel trailert, all I have left is the shower and head. I have some electrical questions and looking for advice.
I am thinking of going with 50 amp service as well. The trailer currently has a 30 amp cord running to a dead converter. I am thinking I need to add a service box then run the AC out of that on breakers .
I am not sure the best way to go here but one option I guess is to go with a converter to power doc and charge batteries, then install an inverter. What I can't figure out is how to get AC to the outlets from the inverter without some sort of switching, don't wanna cause problems with two sources of AC trying to feed outlet at same time.
I know on boats they make charger/inverters that handle the switching for you but the camper ones I have seen are too expensive, any suggestions? I'd like to settle on a plan so I can get this ordered.
Thanks
Tim
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 24, 2025
