- 2oldmanExplorer II
enblethen wrote:
If you were stupid enough to not flip the breaker, yes. And you should do that anyway, then maybe the sockets wouldn't get burned up.
You would use the metal pry bar only once! - What if you turned the breaker of first :E
- You would use the metal pry bar only once!
- Empty_Nest__SooExplorerThe two hot legs of a 50-amp RV connection are each 120 volts, 180 degrees out of phase. Between each hot leg and the common neutral you get 120 volts, which is the way an RV uses the power available in the pedestal socket. However . . .
Create a short between the two hot legs using a metal pry bar, and you will experience the power of 240 volts. :)
Wayne - Mr Wizard: Hope you don't start an argument about RVs not having 220 (240) volts.
- wa8yxmExplorer IIII see two suggestions above I have used.
Plug dogs (worked well till I had to do some mods As part of the mods I needed a short male 50 amp pigtail so I got out my hacksaw and hacksawed the Shore cord.. put a POWER PULL type plug on the cut end and used the part I cut off to do the Hughes Autoformer "install")
Both work well. - MrWizardModerator
joebedford wrote:
Pry bar from HF?
yeah use a steel pry bar where there is HOT 220v electric connections
NOT funny Joe
and NOT safe - Tom_BarbExplorer IIGet a mid sized Zip tie, make a circle of it and place it under the plug to help remove it.
- If you get a straight plug instead of the 90 you could just have the RV pull it out :B
- joebedfordNomad III.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
