pianotuna
Aug 14, 2016Nomad III
Hi,
I'd recommend checking the voltage drop under load at the 30 amp source. You may find that it drops off more than expected.
I check voltage with a 1500 watt heater running.
deercamp01 wrote:
Thanks for the good input. Regarding source voltage, I verified the source voltage is stable and 120. I agree having 50A service end to end would be preferred but unfortunately limited with 30A source service so I need to either "jumper" the end or use a converter plug at the source end (50A female to 30A male).
Thanks again for the guidance!
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
