pianotuna
Jul 25, 2017Nomad III
Hi CA Traveler,
Because the OEM relay had burned contacts within 12 months of my first use. Because the circuit also blew three sixty amp fuses. I replaced the fuse with a 50 amp automatic circuit breaker. It has been fine ever since.
CA Traveler wrote:pianotuna wrote:Why so much higher than 50A?
I'd upgrade to one that is rated for at least 100 amps. Mine are 200 amps.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
