pianotuna
Jul 28, 2017Nomad III
CA Traveller,
The 60 Amp fuse is OEM and is 12 volt for charging the house batteries. I upgraded to a 2nd #8 charging path and both are protected by 50 amp automatic reset breakers. The most I ever "saw" being used was 77 amps--but occasionally I'd get no reading on the 100 amp meter.
I do have manual control over the relays.
I do know the Magnum 3012 hybrid inverter charger comes with a transfer switch rated at 60 amps. It has a time delay on connection while it does voodoo of some sort. It often "clicks" once and then allows connection on the second attempt to hook up to shore power.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
