ScottG
Jan 16, 2019Nomad
CA Traveler wrote:DrewE wrote:Sine waves for sure. But a 240V motor sees that the combined voltage and amps are 120 degrees out of phase with each other. So definitely no longer 240V single phase.
Although the two phases are 120 degrees from each other, the phase to phase waveform still works out to be a sine wave, so it's "normal" single phase power albeit at a lower voltage. There are plenty of single-phase motors that are rated to operate at either 208V or 240V (and likewise plenty that are not so rated).
As long as the motor and it's load is designed for both power sources then all is good. Appreciate the input.
The 240V is still single phase:
Split phase
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
