Bill_Satellite
Jan 18, 2019Explorer II
23hotrodr wrote:Bill.Satellite wrote:
We discussed the install and the installer was very familiar with an RV plug. I had just never seen the 208 setup and was looking for confirmation that using that was not a problem since I never use anything other than 120.
Since you have confirmed the electrician will properly wire the receptacle--
208 3 phase will yield the following in your situation--
208 volts across 2 hot leads
115 volts from each hot to neutral
This will work perfectly fine. You can and should confirm it with a volt meter. Good luck-- Mick
Thanks. I already had planned to do that!
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
