CA Traveler wrote:
208V Shouldn't be a problem with RVs that don't have 240 AC motors or appliances.
But are you guys really sure about what you're posting for condos, etc. I've always believed most appliances were 120/240V single phase. And you seem to be suggesting 120/208 2 phase (120 degree phase) difference is OK, I'd have reservations about single phase motors on this power. Plus my understanding is the target voltage is +-10% or 216V and not 208V.
In my house every AC has 2 motors. The dryer is gas with a 120V motor. Don't know what motor power an electric dry requires.
BTW Every home/condo that I'm aware of uses 120/240V single phase.
Although the two phases are 120 degrees from each other, the phase to phase waveform still works out to be a sine wave, so it's "normal" single phase power albeit at a lower voltage. There are plenty of single-phase motors that are rated to operate at either 208V or 240V (and likewise plenty that are not so rated).
In apartments, more so than in condos, major appliances are usually supplied by the landlord as part of the unit. Naturally if they happen to have 208V rather than 240V power for the dryer or air conditioner they would select units that are appropriate for the supply. Smaller window air conditioners such as a tenant might have and use on their own would generally be 120V.
